Peoples
- Jul 13, 2004
Hello,
I am kinda new in this DIY audio stuff and all, so bare with me. I have build CMOY on a protoboard, here in Finland there is no way for me to get an radioshack one. It works fine sure, but when I turne my amp on, even with no source plugged in, I hear this quite annouing "fuss" distortion kinda sound, something like *wap*wap*wap* :B Hard to explain, I think it has something to do with my Groundings/Potentiometer. Using ALPS 10K (STRK09707) pot. CMOY amp is built into a plastic casing. I was just wondering, how should I ground those connectors and does somebody have a clear explanation how to wire the pot the right way(the pot is upside down, with a piece of protoboard on the legs to help the soldering, I think for 1# that the ground and Input have swapped places, 'cause turning the volume up make the volume go smaller). This is how I have connected the pot, 1# row of pins(left/right) = Input Socket, 2# Amps PCB Input, #3 Signal Ground. At the moment I have wires going to the pot ground(2 pins soldered together, and wire from each socket(3.5mm and 6.5mm(1/4")soldered to that point(probably doing this the wrong way :B). I think the problem lies somewhere here, I get no heat at all from any off the components, I used a multimeter and a 3.5mm-RCA cable to figure out left/right/ground on the sockets. Please contribute all of your advices, they maybe crucial :B If I just could get that loud hiss/fuss away it would be great. After this quite confusing post I am still pretty sure that the distortion is because of me; 1# wiring the pot wrong, #2 Doing the grounding wrong.
King regards, and thank for all those who have the time and willingness to help one DIYer in a trouble.
