Baron5
- Jun 27, 2008
Hey guys,
A while back I made a cmoy which i could never get to work, now i have finally got around to rebuilding it since i have been studying electrical energy systems for my degree and though i would be able to get it working. Both times i have seemed to end with the same problem, there is a lot of noise which is not varied when using the potentiometer volume. And also only very quiet music coming for the left channel. I'm not sure what i have hooked up wrong if anything but have got some pictures for you guys to examine. Is it possible that just the wiring of the i/o is wrong? I have checked the v+ v- pins on the chip which are exactly the same with opposite sense, same as the capacitors to ground. (both +or- 4.46).
I have soldered the resistors in this pictures underneath the board because of the layout, don't worry about the long leads bent around i know they are not touching anything else i have only left them long because i thought i may have to take them off again to rebuild.
Please note because of the board i used i had to use a hobby knife to cut and rip up a small part of the tracks in order to isolate the C2 Capacitors for the output. You can seem them here on either sides of the resistor.
Just the board so you can analyze the layout better, can understand why i had to cut the track in order to keep the same layout of the cmoy guide.
I would greatly appreciate and help. Thanks guys.
