samsquanch
- Jun 3, 2009
It looks like you've made a bridge between the in+ and in- of your chip
You seem to use a lot of solder, try using less, you'll make fewer accidental bridges. Also, when working with stranded wire, you should tin the stripped end before soldering it to your board, this will help the wire make a good electrical bond.
