tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
- Sep 27, 2001
The input impedance of the op-amp chip is on the order of megohms, which means that it's really easy to "drive" -- it requires very little current. This is good in some ways, but it also means that weak signals like radio interference can also drive the op-amp. R2 is in parallel with the op-amp's input impedance: 100K in parallel with "megohms" effectively equals 100K. In other words, it lowers the input impedance of the op-amp to make it less susceptible to RFI.
R2 is also in parallel with the pot's resistance, and it has the same kind of effect. If R2 isn't sufficiently large, as you rotate the pot's shaft the input impedance of the amp will shift. This can affect your source in small ways. It's a problem you should avoid, but it isn't likely to cause extreme bad sound.
If the sound is bad only when the pot is all the way down, and never at any other position, you've probably got the pot's wiper and input backwards -- swap the wire going to the input jack with the one going to C1. If I'm right, when the volume is all the way down, you're effectively grounding out your source in that configuration.
