rebe
- Dec 18, 2006
I'm currently within the return period for a pair of Creative Aurvana Live!, which are nearly identical to the Denon D1001, and the Audio Technica A700. The A700 is far more comfortable and sounds far better, but my ears still get hot.
My problem with the 1001 / Live! was both the sound and the comfort. They sounded much more canned to me, without the depth or soundstage of the Audio Technicas. Since I wear them while working, I find it easier to concentrate if the sound isn't being beamed straight into my brain. Regarding the comfort, the earcups pressed my earlobes against the side of my head, making a earcup/lobe/head sandwich that got hot and sweaty really fast. Unpleasant.
Overall, I like the A700, but I'll return them if I can find something that doesn't make my ears sweat but is still a closed phone. I have the AD700, which are great, but they're big and not suitable for library use (too open). The A700 sound nearly as good to me: much bigger soundstage than the 1001, not quite as big as the AD700; not quite as crisp as the AD700. They don't get much good press around here, but in my opinion they're well worth the $40 over the 1001. Even without the earlobe sandwich, and while far more comfortable overall than the Live!, my ears still get hot after half an hour or so.
So, are there any closed phones that won't make my ears hot? Or is that just an intrinsic part of the design?
Wish list: Closed phone that won't make my ears hot with...
-- fabric / velour ear pads
-- circumaural
-- light clamping force (love the 3d wings of the AT)
-- single side cable
-- wide soundstage
-- no more than $250
-- somewhat portable (fit in largeish backpack with a laptop: I would consider the Live!s semi-portable, but the ATs are just huge)
Will listen to alternative, new wave, electronica, world music. Driven by Macbook Pro, ipod classic, iPhone 3G. No amp.
Any help will be appreciated!
-- circumaural
-- wide soundstage
