lazybum
- Dec 12, 2009
Hi i'm a bit confused about how clipping is related to gain and playback volume.
Ok so i understand that if a signal goes above 0db clipping will occur? So to prevent clipping gain is usually lowered to give more headroom?
Then how does playback volume fit into the equation?
When the gain is lowered, volume is lowered. But its possible to pump up the playback volume such that it sounds as loud as the original, but clipping no longer occurs. Why is this so? Whats the difference between gain and playback volume?
Will a very low gain but high playback volume sound different from a normal gain and normal playback volume, if the loudness is matched?
