jmoore914
- May 24, 2013
Hey guys,
I just got a new Clip Zip but I was having trouble getting Rockbox installed on it.
I am just using the Rockbox Utility and stable build with the 1.20 firmware but after I run the utility and eject (manually, the eject button in the rockbox utility gives an error) nothing happens. When I reboot, it starts normally, no rockbox.
I am using a Mac and no SD card in the zip if that makes any difference.
Thanks,
jmoore914
Thanks,
jmoore914
