- Mar 20, 2013
Long story short - I was asked by someone on whether or not I can build a balanced cable for 1MORE H1707 awhile ago. Though I ended up didn't build the cable as that person went for an alternative option, I did look into the possibility and got myself a pair of extended 2.5mm TRS plugs that are meant for Sennheiser HD700, but said to fit H1707 as well. I was planning to build an balanced cable out of them, but I thought an MMCX adapter design might be a more challenging. In any case, I don't own a H1707 nor planning of getting one, so this is really more of a proof of concept if anything else.
What you need:
1) HD700 2.5mm TRS extended adapter, a pair.
2) MMCX socket, short screw-on type, 1 pair
3) 2 pair of short wires, an inch or so each. I use Estron cable here.
4) Glue. I use UV glue here.
5) Soldering supply
First, solder the wires to the MMCX socket. Note that you can only use the 'short' version of this kind of socket as the long version will be too long for the 2.5mm TRS adapter.
This is the tricky bit - You need to put the nuts into the 2.5mm TRS housing, then try to screw the MMCX socket in until they are tight. It is actually not quite as easy as it seems as the nuts is just a tab smaller than the inner diameter of the housing, so it will want to free spinning around with the MMCX socket instead of trying to screw itself tight. Just know that it can be do - once it is tight, you want to affix them in place so they'll never come loose again. use a tiny drop of UV glue on the inside. Becare not to use too much glue here.
This step is easy, just solder the wires to the 2.5TRS jack. It takes about 3 rotation to screw the TRS into the housing, so I twist the cable anti-clockwise first, then screw the TRS in which the wires to untwist themselves on the inside.
Done.
Here is how it looks with MMCX balanced cable.
Afterthought: This project looks simple enough, but the trick bit of securing the MMCX socket inside almost ruin one of the 2.5mm TRS jack. I were lucky that I have managed to salvage the parts and rebuild it again, otherwise the whole project will have to go into the bin. Given the difficulty, I am not sure I'll recommend others to try this - build a whole cable will be a lot easier.
Great work, useful! Thanks!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
