holland
- Jun 15, 2007
I'm putting a BOM together and am thinking of doing an external power supply. I'm looking for some connectors that would work well, and would not be confusing.
I found one, but I haven't heard back from the manufacturer about where to buy and cost and other available options. http://www.lappusa.com/catalog/LS1Overview.htm
The other one, I'm looking at is what Ray Samuels uses on his Apache and B-52. http://www.raysamuelsaudio.com/products/apache Does anyone know what that is? It's not a standard 5-pin DIN.
Worse comes to worse, would a standard 4-pin DIN handle the power requirements? What is the current rating for the CK2III power section, and for the sigma22 (I would likely use the same connectors)?
Thanks!
Thanks!
