Originally Posted by zer061zer0 /img/forum/go_quote.gif
Can i check with you whats the minimum Mv to reach class A.
"Class A" is load-dependent. Basically, with a push-pull output topology like the CK²III, the output stage quiescent current must be at least one half the peak output current in order to remain in class A. Let's assume a 32Ω load and you want to deliver 100mW of peak power. Then calculate the peak output current: P = I² * R, (P is power, I is current, R is impedance), solving for I gives I = √(P / R) = 56mA, so if the output stage quiescent current is 28mA it will remain in class A up to that output power level. The default recommendation is 30mA, pretty close to that. When the volume is increased beyond that, then the amp will operate in class AB until the maximum voltage swing is reached (at which point the amp will begin to clip).
The default quiescent current of 30mA causes about 14mV drop on the 0.47Ω output resistors (simple Ohm's Law V = I * R).
The calculation above assumes a resistive load. Real "32Ω" headphones may have an impedance curve that drop below that at certain frequencies, so the current demand would be higher than what we assume.
Using the above example you can calculate what it takes to remain in class A. Obviously, the higher the quiescent current, the more "deeply" into class A the amp runs and less likely to drop out of class A from various load conditions, but then the output transistors will run hotter, requiring heatsinking.
