cgrums
- Oct 27, 2006
Morning All,
I populated my second CK^2III board that I'm going to be using in my work setup along with a pair of new A900s. I took a page out of others design books by putting the toroidal transformer in it's own 'wall-wart' box with an umbilical running up to the box. All parts are those recommended by AMB.
The problem: the measured voltage across either of the secondaries from the transformer are ~20 VAC unloaded. This is just as expected. When I connect one of the secondaries (one only) to the CK^2III board the measured secondary voltage drops to ~8.3 VAC. This is not right.
I only connected one of the secondaries because I'm short on the crimp connectors for the recommended terminal blocks.
I observed the same effect on both AC input points from both secondaries.
The secondary that is unloaded continues to measure ~20 VAC when the other secondary is connected to the board.
Any thoughts? I'm kind of stumped. I'm going to use alligator clips when I get home tonight to connect both secondaries at the same time.
Thanks,
cgrums
Thanks,
cgrums
