suicidal_orange
- Aug 10, 2008
This has probably been discussed before but I don't know what it's called to search so I'll ask again.
Recently I have started listening to classical music and it is recorded/mastered quieter (as everything should be, but thats another rant!) so I've had to turn my amp up.
There is a noticable constant buzz during quiet parts - maybe 60Hz mains hum? If I join either RCA ground to the case using my finger and thumb the noise stops almost instantly, but using a wire does nothing. Is there an electronic component that acts like a human conductor I can attach to solve the problem?
This is with noting connected to the inputs, so it's definitely an amp problem. I'm in the uk so it's on 3 pin mains power including ground which is connected to the PCB. Components are all default for 4.1x gain except it has a 10k stepped attenuator for volume. Probably too much info but rather too much than too little
Feel free to link to a thread with answers, I'm sure this is a common problem (that or my first DIY build is rubbish, despite sounding great for 6 months of near daily use!)
