gvl2016
- Oct 18, 2016
Some mobo chipsets are known to resample internally on the way out, even if you get the format you wanted in the end.
I'm using a Z77 mobo, format is set to 16bit 44khz with all enhancements off, background processes have been terminated, Mojo and Hugo have a red light confirming the output is PCM 44khz. If it were resampled to anything else ,E.g 48 khz, the light would be orange not red.
A bit off topic but interesting I hope:
RE: IFI SPIDIF iPurifier and similar......Do they make a difference.
I can answer that definitively. maxh22 would definitely hear an improvement. gvl2016 will not. Not because of what it does, but because of how we hear.
That is, if you are not doing a double blind test, then we all hear what we expect to hear. J.J. Johnson, an engineer with DTS has done a lot of work on audible perceptions, and has one of his discussions posted on youtube HERE. The most relevant section starts at about 1:00 minute in and goes til about 5:00 minutes in. The whole video of the panel discussion is interesting I think. Our brains are hard wired to always hear things in context. (google the McGurk Effect for proof).
For many years I sold audio components and was intrigued by the fact that almost none of the really expensive cables we sold ever got returned. I knew many of my customers did not have very discerning ears. Since these customers expected to hear improvements, they did. Today with digital sources this kind of discussion focuses more on DACs and digital conditioners, most of these sources measure incredibly well,and their sales also benefits I am sure from our expectations.
But that is also is part of the fun...and there is no way around how we perceive, so if it is in your budget and makes you happy go for it. Until manufacturer's provide proof with double blind testing, I will remain a skeptic on most of this stuff.
I can definitely hear the improvement when I correctly adjust CCA's tone controls. If that means its not bit-perfect, I will try not to let that bother me.
...Climbing off the soap box now. Watch the video, fascinating I think.
It could resample to say 48kHz first, then to 44.1kHz on the way out.
Meh, I was the one who recently reported the improvements with the iPurifier. I didn't need a blind test to hear them as it wasn't one of those "maybe" cases. The sound is much more in focus with the iPurifier, the fuzziness is gone. Thing is the DAC I now use is almost 30 years old and has no jitter correction. Whatever clock is recovered from the SPDIF signal is used throughout the DAC so jittery sources IS an issue. Expensive modern DACs with DSP like those from Chord usually have built-in measures to deal with jitter, so there is no benefit to be realized with the iPurifier or very little. If one has the budget to give it a shot sure, just need to set the expectations right based on the rest of the gear.
I use Tidal exclusive mode which takes exclusive control of the Spdif driver, this avoids any windows processing.
Something that has stopped me from getting an iPurifier is that Chromecast Audio doesn't support gapless playback, and I've read that the iPurifier makes it even worse. That and the thought of buying an accessory for the Chromecast Audio that costs over 4x as much as the CCA itself.I saw a few posts from several users recommending the IFI SPIDIF iPurifier, I might pick one of those up later on to further refine the sound but for now I am happy with the performance of the device
I see a that there is a new 2018 version of Chromecast Video that will probably be announced on Oct. 9. Apparently Target stores are currently closing out the CC audio.
Does this mean the Chromecast Audio will be updated or discontinued?
My guess is that it will be discontinued. Google is pushing their Home devices...like the Home Mini pretty hard. It now has bluetooth audio transmitting capability and for many non-audiophiles that may be all they want. They could also come out with a Google Mini version 2 with audio outputs (but I bet no optical outputs).
Would you be happy with an updated Mini? This thread in an audiophile community has slowed down a lot. Perhaps for many Bluetooth sound and functions are good enough.
