trickyRoadsDummyTOOL
Apart from the fact that my headphone amp does not provide balanced output and may not come close to GSX mini, this is pretty much my configuration. OK, I have a preamp between Mojo2 and Headphone amplifier. Indigo not only being the proposed voltage level, but also leading to the best sounding results to my ears, i adjust HPA-output between 60% and 75%. Interconnects from Mojo2 to preamp is 3.5/RCA and balanced from preamp to HPA.I am now running my Mojo2 into a Headamp GSX Mini via a Moon Silver Dragon 3.5 to stereo RCA wire. Out 5 pin balanced to my TH900. The results are great, but only when Mojo2 is set to double deep blue, a good bit above indigo unity gain. Anyone else finding this to be the case in this use case situation of running into an amp?
HPA in GSX mini price range is my next acquisition, alternatively v550 (violectric). How was the difference if you use GSX mini with SE output?
