Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
Feb 14, 2023 at 11:18 AM Post #6,916 of 12,501
Rolling with a similar setup at work.
Omoton stand + Apple MagSafe + Apple iPhone X + DDHIFI HFi09s + Mojo2 + ALO Gold 16 + 64 Audio Trio
The EQ on the Mojo2 is simply amazing… The ease of making incremental changes to the sound has transformed at least one pair of IE monitors and a couple pairs of headphones into sonic bliss. I‘ve never really been interested in EQ my music (A&K’s EQ is crap), but the Mojo2 makes it effortless. Chord has won me over and I’m hoping that there is an updated Hugo on the horizon for my next step up.
I forgot to attach the pics I took!
Feb 14, 2023 at 11:57 AM Post #6,917 of 12,501
I personally think it is good to show Mojo 2 owners who might be considering a Poly just how many headaches Poly user’s are still having with a device that Chord still can’t get right after, what, 5-6 years.
It is right if you use it right. I use it every single day and don't notice the shortcomings at all.
Feb 14, 2023 at 4:15 PM Post #6,919 of 12,501
People who are happy with a product tend to post much less than the disappointed ones.
I bought my Poly when it was first released (11/17). I use it mostly for Roon, occasionally for mSD playback.
The only problem I've encountered was with my old mesh network. Since I got the Asus XT8, it's been absolutely flawless.
Feb 14, 2023 at 6:35 PM Post #6,921 of 12,501
I’ll be chucking my money at them when a Hugo 3 with lossless EQ comes out … I’ll sell body parts if I have to
I think there will be a huge line of body parts! It’s a common recurring request here.
Also a common recurring theme is Poly. Mine is … and has been … transformational and effortless. Issues used to happen until they got stability. A pleasure every evening and yes connecting to 4G through the polys hotspot is completely doable (on iPhone) but you need to know how. I’ve forgot!
Feb 15, 2023 at 1:01 AM Post #6,922 of 12,501
Yes but not immediately, when I connect my smartphone to the Poly in hotspot mode, at first I have to deactivate the data network, then after control the music inside the micro SD through the MPD App, i can reactivate the data network and without any problems, and the MPD control App continues to work
Thanks! Does MPD App available on Android?
Feb 15, 2023 at 1:52 AM Post #6,923 of 12,501
OK @daveya is right, I'm going to have to agree, questions relating directly to using Poly should be asked over on the Poly thread.
https://www.head-fi.org/threads/chord-electronics-☆-poly-☆-wireless-microsd-module-for-mojo-☆★►useful-info-on-1st-page-◄★☆.831347/
Feb 15, 2023 at 9:18 AM Post #6,925 of 12,501
For those looking for a cheap DDC to connect with your Chord Mojo, consider the SMSL PO100 Pro.
First impression: it's letting the Mojo perform with no issues stemming from EQ adjustments, something I dealt with while connected via Mojo's USB port.
For $70.00, it's all I could ask for. Recommended.
Thank you :)
Feb 18, 2023 at 8:08 AM Post #6,927 of 12,501
Anyone else getting fairly audible hiss mainly on the left channel using sensitive headphones (in my case Final Sonorous III) with the Mojo 2 ? Or could my unit be defective ?
Feb 18, 2023 at 2:56 PM Post #6,928 of 12,501
It stands to reason that anything that is happening on one channel only can only be due to a faulty Mojo 2.
That of course assumes you have narrowed the problem down to the Mojo 2 by trying different sources and headphones/IEM and the problem remains.
Feb 18, 2023 at 3:28 PM Post #6,929 of 12,501
Indeed, that happens even when the Mojo 2 is unplugged, and with 2 of my more sensitive headphones.
Feb 18, 2023 at 3:36 PM Post #6,930 of 12,501
Have you tried other sources?
other DACs.
May sound silly, but it could also be your ears.
Swap the earphones around, see if noise goes to other ear, if it does, it couldn't be the ears.
