Amberlamps
Formerly known as Phuca
- Jan 22, 2017
Chord Bold... From the bolt jumping spider. Thats all I can say...
You should get banned for posting the above.
Yes, I’m petrified of spiders.
Ugh, dealing with phobias sucks, I’m sorry.You should get banned for posting the above.
I always had an idea that the reason to own DAP in the first place is that you do not need your mobile in the first place to listen to music at any place, any time without much compromising the SQ. Pairing Mojo (classic) with Xduoo transport gave me similar setup minus wifi connectivity. Just my 2 cents...If Chord create something with all the advantages of a DAP; bluetooth poly functionality, and no screen or useless Ui, as we all prefer using our phones as a control center anyway, they'll tear out the jugular of the DAP market.
The entire issue with DAPs is so much manufacturer cost goes into a screen & visual UI. Also battery life too.
If Chord eliminate this in essence useless side of the DAP, while having better SQ, as a Mojo Poly does already compared to most DAPs, honestly that'd be it for any DAP in the price range of the Mojo 2. Game set match. I hope they do it, really.
Hence the notion of a screen-less DAP with its own card reader, that can be remote controlled by BT.Fine, as long as your phone has enough storage (and isn’t running a whole bunch of other apps in the background whilst you are listening to music)…
I don’t think this is possible. LDAC is lossy.If the BT is LDAC capable, one can also get CD quality or better from streaming
BT is lossy, period!I don’t think this is possible. LDAC is lossy.
agree and I hope the new one will be a portable mojoNeither the Mojo or Poly, for different reasons, have been very successful as truly portable solutions.
Not unless the streaming app developer adds this as a feature. But what would be the point? Just BT the phone to the theoretical Mojo2 and be done with it.Then once the downloads were complete, wouldn’t one be able to disconnect the wired connection, establish a Bluetooth connection, and control the downloaded library on the Mojo 2 wirelessly, via the streaming app?
