jboehle
I want to build a simple CMOY-like headphone amp with the AD8397 chip. But I want it to be optimized for my Grados. I want to make the gain=2. So in the following schematic, I need to make R3 = R4, because gain = (1 + R3/R4). But how do I choose the actual values for R3, R4, and the rest of the parts?
I was going to take Tangent's new PINT schematic (http://tangentsoft.net/audio/pint/misc/sch-0.93.pdf) and just make the L/R channel portion of the amp, but the gain is not equal to 2. So why not just make R3 = R4? Because in the thread on the PINT, Tangent says:
Ignore the mention of C3, as I think Tangent determined a compensation cap across R4 was not necessary.
So, how do I know how C1, R2, R3, and R4 interact for bi-polar amps? Where should I start reading to learn how to determine the correct values for those, for a decently long-life battery powered amp, but avoid amplifying noise? I thought C1 was just to block DC from your source. Is that just for FET-input op-amps, and C1 plays a different purpose for bipolar op-amps?
I've read part of and skimmed over the rest of "Op Amps For Everyone", but it doesn't really cover the particular questions I'm asking (or I skimmed over it).
TIA.
Originally Posted by tangent With bipolar-input op-amps, the C1, C3, R2, R3, and R4 values all interact significantly. Change one, and they all have to change to keep all else substantially equal. If R4 is cut in half, C3, R3, and R2 are also cut in half, and C1 must double. [...] An entirely different way to go is to short C1, make R2 high so its interaction is all but irrelevant, and try to balance the feedback R's against the pot's varying resistance. This can work with some op-amps, and obviously it gets the feedback Rs very low. But it requires very careful calculation to avoid getting the DC offsets too high. It might require adding a series resistance between the pot wiper and the op-amp input to make it practical. I'll have to do some calculations and get back to you on that. |
TIA.
