Slater
Hey, UiiSii CM5 owners - what do you make of the mesh in the nozzle. If you shine a light on the mesh, you can see there is a silver foil "cover" directly under the nozzle mesh. It looks like it's 100% blocking the nozzle. If you very gently push on the nozzle mesh with a toothpick, you will see the metal foil underneath 'flex'.
The mesh is glued on with some pretty serious soft glue, so I don't want to destroy everything just to see what the deal with the foil is.
I wonder if the foil is acting like a passive radiator (if that's eve possible)? I've never seen anything like it in an IEM. There's no holes or pores in the foil - it's literally solid and covers the whole diameter of the nozzle.
It doesn't show up on photos, so sorry I can't post what I'm seeing. But if you remove the eartip on your CM5 you'll see what I'm talking about. Very weird.
