Cheap DAC with Ethernet Input? Lan vs USB
Sep 14, 2012 at 6:05 AM Thread Starter Post #1 of 10
sapho
Hi,
Does anyone of you know a cheap DAC with an Ethernet input?
In fact, I needed two inputs: 1 digital for CD, 1 LAN for PC.
Are there differences between the quality of the signal via USB and through LAN?
How looks problem with jitter via Ethernet?
Why only expensive devices offer Ethernet input?
Sep 14, 2012 at 2:55 PM Post #2 of 10
eithernet input?  I'm assuming you're not talking about an i2s connection.  I'm guessing what you're really looking for is a network player/network bridge and not specifically a DAC?
Sep 14, 2012 at 6:41 PM Post #4 of 10
Sep 16, 2012 at 10:29 AM Post #6 of 10
Yes, you have right.
I'm looking for network streamer, with usability such as devices like Linn MAJIK DS, Pioneer N-50, CA Stream Magic6 , which can streaming music via Cat-5e cable.
But I'm looking for cheaper solutions (for example without LCD screens).
Sep 16, 2012 at 10:46 AM Post #7 of 10
I'm curious to hear the opinion about of the differences in sound quality when music is streamed directly from a PC via USB or Ethernet.
The USB transmision can add audible jitter. The same effect occurs in Ethernet streaming?
Sep 16, 2012 at 12:07 PM Post #8 of 10
It depends on the implementation. Both can achieve transparency with jitter being far below what is audible. Most professional gear has firewire and increasingly USB connectivity.
Sep 17, 2012 at 10:23 AM Post #9 of 10
Not completely what you're looking for but a solid audiophile player that doesn't do anything but play music (from a hard drive, or a specific NAS or...) and has a ethernet port is the pk90 and pk100.  Use your phone or ipad or computer as a screen so the player doesn't do ANYTHING but play music.  The 100 has a simple DAC in it that's supposed to sound pretty good and a BNC/COAX out but the 90 is only usb out.
Sep 19, 2012 at 2:17 PM Post #10 of 10
Marantz NA7004 will do what you want it to do, and is $800.  Is that more in your price range?
