morethansense
- Feb 6, 2011
So, due to me recently being disappointed by an "upgrade" cable purchased on eBay, and my severe reluctance to dole out more dough on cables than the AUD$160 I paid for this set of in-ears, I decided to build my own.
How hard could it posibly be, right?
I hope I'm not breaking any rules, these links aren't for advertising, merely illustration purposes.
I purchased IE8 connectors from here
3.5mm Neutrik NTP3RC Mini-TRS Jack from here
24AWG Silver-Coated Teflon Wire from here
(White for both grounds, blue for left, brown for right.)
And a large amount of various diameters/colours of heat-shrink, but the main body of my cable will be wrapped in this. I hope my cable won't be as stiff as a baseball bat.
If I feel like it, I might add fabric sheathing, but only if the bare cable/heat shrink is REALLY ugly.
These are the instructions I will follow:
Cut teflon wire to approx 6ft length. (Blue, Brown, 2xWhite)
Braid. http://www.chimeralabs.com/diy_braid.html
Large-diameter heat shrink length-minus-foot
Twist each branch a full rotation/~10mm.
Small-diameter heat shrink left and right
Large-diameter heat shrink Y-split twice - 20mm, 40mm
Slot ~120mm large diameter heat-shrink left and right.
Slot ~50mm small-diameter heat-shrink left and right.
Clamp.
Tin Wire.
Solder IE8 connectors - blue left, brown right.
Heat shrink small diameter, left and right.
Apply strain relief on top of small-d heat shrink
Braid/Twist moulding wire
Align moulding wire inside ear hook
Slot inside large diameter heat shrink
Heat shrink large diameter, left and right.
Slot ~50mm large-diameter heat-shrink
Cut 4.8mm heat shrink tube black to 15mm length
Slot heat shrink and 3.5mm housing to braided cable.
Tin Wire
Solder 3.5mm connector - blue left, brown right.
Heat shrink 4.8mm
Screw 3.5mm jack housing.
Test.
If working properly, glue 3.5mm thread and re-tighten.
Will post as many photos as possible as stuff arrives,
Clamp.
Tin Wire.
Tin Wire
Heat shrink 4.8mm
Test.
