Chassis source in the US?
Sep 23, 2009 at 4:37 PM Post #33 of 44
rather go powder coating...lot more color options and more durable.
And it is cheap..though U can't have DIY kit for powder coating
My EHHA is powder coated..click on the link in my sig to see a pic of it.
Sep 23, 2009 at 4:39 PM Post #34 of 44
Originally Posted by Dougie085 /img/forum/go_quote.gif
Caswell Inc. - LCD Aluminum Anodizing Kit
Hmm not as cheap as I had hoped. I wonder how much anodizing I can do with that kit. And I wonder if I mix up a whole batch of stuff will it hold over till later to use again or if I have to start over? If the later then would have to get a bunch of stuff together that I want to anodize and then do it all at once.
Well, you need to setup a place for anodizing, guys use this camping dridges to keep hemicals safe and clean ...
All you need is to time to time refresh battery acid and to buy dye .. And destilled wather ...
You can also go and buy all this stuff in the store by your self .. just look what is in the kit ...
Sep 23, 2009 at 4:42 PM Post #35 of 44
Maybe is good choice to look around your hometown is there is some anodizing shop ... Audio enclosures are usualy black, and wont be too much for that job ... i mean wont be custom job ...
Sep 23, 2009 at 4:44 PM Post #36 of 44
LoL, there is : Hot Coat
But, on this site is even more metal finish kits for DIYers: Eastwood
Sep 23, 2009 at 4:52 PM Post #38 of 44
Yeah I was going to say I've seen at home powder coating setups and people bake them in their ovens! Which is a bit crazy unless you have an oven you don't use for cooking.
I found this site that has a lot of info on anodizing.
Anodizing Aluminum
Yeah, is interesting, i would like to do this too .. But - i am in Germany, and they wont ship here, ground shipping only for chemicals ..
Sep 23, 2009 at 4:54 PM Post #40 of 44
lol I take it back..so they do have kits for powder coating. haha
But sersiouly who wants to deal with the mess..I'd rather have it done professionally. Unless you are getting a lot of stuff powder coated, I'd want to go to a professional service center. For a couple of enclosures they will do it for 50$ (At least in my town) and I can pick from a 100 different colors.
They even sand blast it for you before coating it.
Sep 23, 2009 at 5:02 PM Post #42 of 44
In some ways this is good as it gives better electrical insulation..Those parts that you don't want the coating on(like the place on a heatsink where the part is going to be mounted) just ask them to mask it and not powder coat that location. This is what I did for my EHHA..the top inside part of the enclosure is not powder coated where the MOSFETs are mounted.
Sep 23, 2009 at 7:28 PM Post #43 of 44
I just did a quick and dirty chassis through FPE and with engravings and everything would of been about 300 bucks. That's 2RU high, 19" wide and 14" deep. That was 4mm front and pack and 2.5mm sides, top and bottom. FPE is kind of pricey in general though.
That doesn't sound at all unreasonable. I'd bet I have more than $300 into the chassis I posted a picture of. The top panel alone was $60 in fab costs with me providing the material.
Sep 23, 2009 at 7:43 PM Post #44 of 44
Well I figured out that cost didn't include the side panels or their little corner things making it all fit together. I could get a similar chassis from one of the mentioned companies and just make some front and rear panels for less. For 300 I could probably get one of the Modu enclosures from over seas as well which are very nice.
