RobertR
- Mar 2, 2002
for xmas I got my first dig. cam. a canon sd110. I think the shutterbug has bit.
The camera uses a rechargable lithium ion 7.2v 790mah.
The manual says to prolong batt. life it should be discharged before each recharging cycle. However some say that it should be charged before depleted.
Also can I use non canon equivalent like the sterling tec batt. which sells for 12.95 and would it be safe to use the canon wall plug charger?
Sorry if this is the wrong site for my question but the cam. is truly portable smaller than a deck of cards.
