Chaintech PCM SPDIF Volume Control
Sep 29, 2004 at 6:28 PM Thread Starter Post #1 of 5
recephasan
I'm using foobar2000.
Is it better to use the volume control in foobar or the one in Windows that is labeled "PCM SPDIF" when using digital out?
I am using ART DIO. Since that is 24 bits, and my original audio is 16, I assume the PCM SPDIF just lowers the values of all output samples. What about foobar2000?
Sep 29, 2004 at 8:23 PM Post #2 of 5
The "PCM SPDIF" volume control, if it operates like the rest of the Windows mixer, effectively decreases the dynamic range to 14-bits unless you have it set to full volume. The Foobar2000 volume control isn't the best either, but it's probably better than the Windows one.
