littlexx26
and any guide for disabling bloatwares?
NOS doesn’t really sound NOS IMO , probably that double filters and OS. So, I don’t worry much about Darwin as an additional features. But MSEB is great to have if you love systemwide EQ.how does it sound NOS?
My 2 weeks old N8ii doesn’t wake up anymore…. Any idea? Last time I switched it off it has approximately 80% battery left. I am on the latest fw. (I tried many things, like charging it for 2 hours and with different cable).
Thanks in advance
Back when I had it, and sometimes it can happen that way, which I don’t know why. But try this combo, plugging in a charging cables, better with a PC than a charger, hold down power, play and forward, possibly 20 seconds. If that doesn’t move anywhere, try Power, play, reverse buttons. If that doesn’t help it then I wouldn’t know
SolvedNo combo of buttons held down for 30+ seconds with the power button work either? If you've gone through all the charging options, IE change cable, charger and so forth and tried the button combo's with no luck, then I think you're out of options and it's time to contact support.
I know what you are talking about, but I can't exactly remember what I did to fix it to avoid having to restart, and can't get n8ii into that state right now. I think it was a back arrow, the back button, or I cycled active windows and was able to get control from another window when active. I think it's just the edit function that goes wonky and freaks out. Wish I could be more help, all my sympathy though. It's a dumb bug.I have kind of a qwirky issue. A bit annoying but not a show stopper. Somehow the pull down menu has gone transparent and it is difficult to see the options. Any ideas on how to correct this ? I have tried resetting everything and didn't have any effect.
Thank you !!!I know what you are talking about, but I can't exactly remember what I did to fix it to avoid having to restart, and can't get n8ii into that state right now. I think it was a back arrow, the back button, or I cycled active windows and was able to get control from another window when active. I think it's just the edit function that goes wonky and freaks out. Wish I could be more help, all my sympathy though. It's a dumb bug.
Edit: I'd ask in the main forum for N8ii, you'd get a better chance for a useful reply.
I reinstalled to factory settings. Had to reinstall Tidal and Qobuz but no big deal. Never have found what caused it.I have kind of a qwirky issue. A bit annoying but not a show stopper. Somehow the pull down menu has gone transparent and it is difficult to see the options. Any ideas on how to correct this ? I have tried resetting everything and didn't have any effect.
