- Jul 30, 2015
Who's being impatient?Andy said tomorrow, so let's have patience.
2998 RMB, is that right? No way!
As were mentioned before - 800mWso what the maximum power can the tube power be at 32ohm?
Well, according to the spec sheet 130mW.so what the maximum power can the tube power be at 32ohm?
Thanks for posting this. So it uses an actual power pentode......oh my word! I cannot wait to see how this sounds in triode mode. It could be the very DAP I thought would never happen.Here's a pretty detailed article that you can use chrome to translate https://www.sohu.com/a/410699705_508755 (the article expands when you click on the orange text after the last picture)
if use 4.4 it will work like hybrid tube or on 4.4 the tube wont be using?Well, according to the spec sheet 130mW.
NO, the tubes work only with the standard 3.5mm output just like Cayin N8.if use 4.4 it will work like hybrid tube or on 4.4 the tube wont be using?
tksNO, the tubes work only with the standard 3.5mm output just like Cayin N8.
