Gradofan2
- Jul 2, 2005
Perhaps... I missunderstood you... but... I didn't missunderstand the AKG tech - who stated simply, "a speaker amp with 30 watts per channel into 8 ohms is the minimum required to drive the K1000s."
Now... if 1-2 watts per channel into 120-300 ohms is equivalent to 30 watts / channel into 8 ohms - then fine... but... if not...
Originally Posted by Ferbose /img/forum/go_quote.gif You misunderstood. 30W into 8 ohms requires 15V voltage swing. But you never know if your speaker amp can deliver 15V voltage swing into a 120 ohm load (actually K1000's impedance goes to something like 300 ohms). On the other hand, Cayin HA-1A can reliably deliver >1W into a 120 ohm load or even a 300 ohm load, which is exactly what K1000 needs. K1000 can be driven by both speaker posts and headphone jack on HA-1A--they sound different. I like to the headphone jack these days. |
