- Oct 10, 2002
Perhaps you mean 100R??
Originally Posted by runeight /img/forum/go_quote.gif And since you will need offboard heatsinks we should look at the Hitachi 2sk1058 and 2sj162 lateral fets or the irfp140n and irfp9140n. |
Originally Posted by runeight /img/forum/go_quote.gif Perhaps you mean 100R?? |
Originally Posted by wiatrob /img/forum/go_quote.gif And what for us BJT's? |
Originally Posted by tennisets /img/forum/go_quote.gif I searched through this thread for a while, but I still have a couple of questions. I was intending to build a balanced M^3, but this project is tempting. My questions: is there anything else that needs to be done to drive speakers other than use 2W resistors for R32 and R33 and a Zobel network across the speaker terminals? I saw mention of paralleling the output devices. Any more info on this? Headwize being down kind of sucks. In addition, would two sigma22's be recommended for speaker use (as in the b22), or could I get by with one (with appropriately sized transformer)? Thanks! |
Originally Posted by runeight /img/forum/go_quote.gif tennisets, I'm going to repeat my reply because I just wrote it out too fast. To make an EHHA power amp you should. 1. Change R32, R33 to 0.47R at 2W. 2. Change R13 to 1k. 3. Supply bigger heatsinking for the fets. 4. Remove R22, R23 I think it's right this time. |
Originally Posted by runeight /img/forum/go_quote.gif Don't let this necessarily discourage you on the speaker amp. It's necessary to give the worst case conditions so that there are no surprises. However, as we know, music is not a sine wave and most listening is done a low power levels, often only 1W or so. The extra power in the amp is used to get dynamic range in the transient peaks. With the big heatsinks that are on this board, if you use the tallest ones, you can probably get pretty loud without overheating the fets. It will be a very rare circumstance where you will hammer out a 40WRMS sine wave, unless you're trying out test tones. If you socket a few resistors you could have both a headphone amp and a speaker amp. |
Originally Posted by runeight /img/forum/go_quote.gif The heatsink that you want is this one: Aavid TO220 Except that this is the 2" tall version and Mouser doesn't seem to have the 2.5" tall version. The 2.5" is the one you want if you can find it somewhere. The holes seem to be slightly off on the boards. We don't know why. However, I have a pair of board (unpopulated) and I have the correct heatsinks and they fit with no problems at all. If you're using s22 supplies, I think that they are spec'd at 1A continuous current and much higher peaks. You can try one and see what happens. You can always build another one if you really need it. |
