I decided to check out this hum situation with my LC. My unit is SN 186. First I don't have any ubber sensitive IEMs. So, obviously this is not important for my use. I just grabbed a couple of sets that I use with my portable gear these days. Tthe Fiio EX1 for SE and for balanced, the RE600. With no signal input (Foobar paused) using SE out I could hear a little hum barely audible starting at 2 O'clock on the volume control. It got quite noticeable at full volume an included a static like component. I then checked with the balanced output. There was zero detectable noise or hum even with volume maxed out at 3X gain. Interesting! I then decided to try to see if it was the amp or inputs that were responsible. I went back to the SE output, cranked the volume to max and unplugged the two XLR cables from the Pulse Infinity. Guess what, the noise went to zero again. In this case it seemed pretty obvious to me that the LC was not producing the noise.
Being curious, I decided to plug the SE out from the Infinity into the LC to see what influence using that input may have on the noise. No noise at all at max volume from the SE inputs and output, even at 3X gain, zero detectable noise at max volume. OK, so I switch back to the balanced inputs. The noise was gone, again even with everything maxed out.
My conclusion is that, for my unit, with the level of sensitivity of the test IEMs, there is no detectable internally generated noise from the LC. The noise present on the SE output, using balanced in from the Infinity, seems to be the product of a grounding problem between the Infinity and LC. Once I bound the grounds through using the cables between the SE input/output pairs there is no noise.
Obviously this worked in my particular setup with my SN 186 LC. There may be differences in individual units. But, this little experiment may give others an idea on something that they may try if having hum problems.
Two things to mention here. First, even without the SE cables in place, I would not consider the level of hum to be a problem. The audio level of music playing at the 2 O'clock position on the volume control (where the hum first became audible) would be more than enough to damage my ears, if not kill the IEMs. In short I would never hear it in use.
Second, and a separate subject, but related, I could hear no channel imbalance at any volume setting in either SE or balanced output, nor using either balanced or SE input.
I realize that all of this only applies to my unit, but it would seem to indicate that there is no intrinsic problems with the design of the Liquid Carbon.
Oh and BTW, I really like the way it sounds.
