Pott
- Sep 11, 2009
I'd like to carry my Noble x Massdrop, a USB OTG Cable, and an Audioquest DragonFly Red DAC/Amp in a single box. Currently I put all three in the typical small case you get with Westone/Massdrop Plus IEMs, but it's a little small.
The 1010, by comparison, is way too big.
Something just a little longer than the Westone-type case would be perfect.
Does such a goldilock 'just right' accessory exists? I took a look around but there's not much that looks like it'd give similar protection on the inside (soft lining/foam to prevent bumping on hard surfaces) and outside (hard case or tough softer material).
Thanks!
Thanks!
