Case for A64 a12t and qudelix 5k
Jul 5, 2023 at 2:53 PM Thread Starter Post #1 of 8
MaxD
I have been looking for months and was wondering if any one else has the same issue or a solution. I have the Audio64 A12t CIEM's and I somtimes use a Qudelix 5k with them. I also carry the DD HiFi micr 2.5 to 3.5 and 4.4 mm adapters. Im looking for the perfect case. But I have been looking so long now....
here is what I am doing today bit its not much good and no protection realy.
Help, anyone :)
Jul 5, 2023 at 3:12 PM Post #2 of 8
I have not found a perfect case, either. Currently using this: https://www.amazon.com/gp/product/B086M5CZJ6
It's not pocketable but large enough to fit a DAP, DAC, cables, and IEMs as long as you use a pouch to protect the shells.
Jul 6, 2023 at 1:58 AM Post #3 of 8
Nice, I hyave a simalar case I use for a dap and iems when traveling. Too big for EDC, I'll keep searching and if I find anything I'll post it.
Jul 6, 2023 at 4:23 AM Post #4 of 8
What does your case look like? Link?
Jul 6, 2023 at 6:46 AM Post #5 of 8
Jul 6, 2023 at 7:24 AM Post #6 of 8
Hey MSING539, I put a pictur of it on the original post ?
Oh, but you can't fit a dap in that. Just the dongle, right?
Jul 6, 2023 at 7:34 AM Post #7 of 8
yes, I have several DAPS each with its own cover / case. I only want to find a case for the CIEM's and the 5k with adapters. Probably looking for somthing secur hard and square to fit them all. My current solution has a memory foam implant to hold the adapters and the 5k goes in the net poket. the iem's just fit in the remainder.
Jul 12, 2023 at 9:46 AM Post #8 of 8
Finaly found it :). Fits both the IEM's and Qudelix 5k in main compartment. The IEM's have a 2.5mm balaenced connector so the DD hifi adapters (to 3.5 and 4.4) fit in the small second compartment with a couple of spare / difernt Apex Modules. I even added a shanling u2 DAC for those emergancy times when the battery is done on the 5k.
This is what I found:
Ringke Mini Pouch [Two Pocket]
Now I can carry a pair of IEM's that make everything sound good and will connect to everything. Thanks for the sugestions.
