Metalomaniac
- Mar 24, 2014
I've been doing AB blind testing of 130kbps MP3s and HDTracks hires audio FLACs. And I'm not able to tell the difference.
I bought The Door's L.A. Woman and Rush's Presto from HDTracks. I compressed them using LAME's v5 settings, which yields a file of around 130kbps. As the source is the same, there's no issue with matching volume, different mastering, etc.
I put files through a filename randomizer, and put them on my "hi-res" MP3 player, Sony NWZ-F886 with FiiO Kilimanjaro portable amp, and KEF M200 IEMs.
Now, hi-res files are eighteen times the size of the 130kbps MP3s, and I was struggling to tell any difference in the audio. After going through the 30 tracks twice over a few months, it is clear that my success rate is purely random.
My gear is entry-level for people on this forum, but mid-range to high-range to anyone who's not. In any case, I would expect to be able to tell the difference between the audio quality of a low bitrate MP3 and hires audio even with this gear.
So, the question is: is my gear really that lacking, is it my hearing, or is hi-res audio snake oil? I've moved to Spotify, and am considering stopping to use the extreme quality to fit more music on my portable player as it seems I can't tell the difference anyway.
