Edil
- Feb 27, 2005
Hi,
Has been using the E4 for a couple of days now. I tried all sleeves and found that the foam tips provided better fit and comfort. All the others cause me irritation in the ear canal.
Problem is that it seems that the shape and contour of the outer canal of my ears are different, left being little bit bigger, and the foam tip forms a tighter fit and better seal in the right ear. The bass sound unbalanced.
Any suggestions?
Regards
Edil
Any suggestions?
Regards
Edil
