cjburr
- May 31, 2010
I'm trying to match up a set of headphones to the output of the controller I'm using to practice and record my guitar with.
Here are the specs for the controllers headphone output.
Load Impedance: 8-600 ohms
Max Output Level: 1.61VRMS @ 100 ohms
SNR (weighted): >91db
THD+N (60 ohms): 0.013%
Frequency Responce: +/- 0,5db 22Hz - 44kHz
The controller receives it's power from the USB port on my MacBook Pro. This set up will be used to keep me from going bonkers when I am working in Afghanistan so using an amp for the headphones isn't something I wish to do.
Which specs are most important to match when choosing headphones.....output voltage and load impedance??, or does any of this matter?
Any suggestions for other things to look out for when choosing a set of cans will be appreciated.
Thanks, Chris
Thanks, Chris
