Hookem
- Apr 8, 2008
Decided I am going to start my DIY with cables and then move to a DIY DAC.
Want to make a stereo mini to mini using the Canare F12's
Then make a stereo mini to RCA using the Canare F12's paired with the Canare F10's
I have seen some pics of Steven Kelby's mini to rca cable and cannot seem to find the junction where the F12 get split for the 2 rca cables.
I need to find the splitter.
A recommendation for what wire I should use that will be sleeved with Techflex sleeving would also be greatly apprecaited...I will also be making some rca to rca cables...So I will probably need 3 and 2 lead wire that is the right size to work with the Canare connectors and the Techflex sleeving with heatshrink...Unless of course I should use something else.
Thanks for any recommendations or help getting all the right stuff the first time out.
