Originally Posted by hawkfire
hello,
To answer jmmmms response, he is absolutely incorrect in his statement of fact as shown here.
IT is indeed a guess on your part as there are many different definitions of vacuum. Accoustics, physics and electronics are but a few.
Let me explain in simple terms.
Vacuum=The condition of reduction of pressure below that of the atmosphere.
Because of this vacuum as defined above, ety and shure triflanges are able to stay in place.
There is no undo pressure at all on the eardrum because air inside the sealed cavity is lower than that of the amosphere. Vacuum doesnt become suction on the eardrum until YOU PULL on the earpiece itself without breaking the seal.
This is how ety users who arent careful in removing thier triflange tips hurt themselves by creating excessive suction from vacuum.
Vacuum and seal is the reason why there is a sound difference between using the foamies and the silicones/customs or triflanges.
Dura has it right as well.
And john rich, my oversight.
The Shure e2 does use a dymanic driver.
I just typed the post off the top of my head is all.
and mem24, vacuum is very much relevant to sound reproduction and iems as to lose vacuum is to comromise your seal and losing seal integrity=no bass and reduced treble and high response.
Sorry buddy, but you are still wrong. Repeating yourself without backing it up does not make you right. First of all, if there are other definitions than the ones given of 'vacuum', please give them to us, and quote a source, please. The only definition that didn't say 'void of air' said a
significant difference in air pressure. So lets give you the benefit of the doubt and say there is lower pressure inside the canal here. If there is this lower pressure, how exactly was it created? Explain that to me. The only way to create a lower pressure area is to either remove air molecules while keeping the volume constant, or increasing the volume while keeping the number of air molecules constant. The only way for the pressure to be lowered in this situation is if the canalphone actually sucked air from your ear canal and moved the air outside after you inserted it. That obviously doesn't happen. And I'll repeat again, if the pressure inside the ear canal is much different from atmospheric pressure, eardrum movement will be reduced, and so will your ability to hear. I doubt this is the aim of canalphone manufacturers. Most likely, the pressure is a tiny tiny bit lower inside the canal, created from the small movement outward as the canalphone situates.
What you claim is this vacuum inside your ear keeping the canalphone in place, is most likely a combination of a few things including friction between the earbud and your epithelium, and the fact that if the canalphone starts to move outward, the volume inside the canal increases while the amnt of air inside remains constant, creating lower pressure inside the canal, preventing the earbud from moving. You are sort of right about the 'vacuum' being responsible for the ety removal injuries. This is probably caused by, when removing the earbud with the seal still intact, you are increasing volume while keeping the # of molecules constant, therefore decreasing the pressure, causing the 'pop' and possible injury to the eardrum.
Dura's explanation seems reasonable, though I don't completely understand it.
