pinnahertz
- Mar 11, 2016
Relative to an actual compressor they do nothing.Transducers can affect the transient dynamics.
Not if operated within design parameters where they are behaving more or less linearly. If you're referring to "Power Compression", (more correctly "thermal distortion")where the voice coil heats up enough to present a higher impedance and lower efficiency, then sure, but that's operation out of the safe design range. And the result is still nothing like the degree of gain change that a compressor produces, though it's time constants are similar to a fast acting RMS compressor.Transducers can affect the transient dynamics.
Agreed. Government speakers operate outside their limits all the time.Anything operating within its limits is not going to have an effect. But speakers are real world mechanical devices, and in the real world limits are exceeded on a regular basis. Just look at the government.
Many say tube sound is nothing more than EQ and designer coloration, if this is the case would it be possible to exactly replicate tube sound through the use of a plugin?
I guess by plug-in you mean some thing for a replay program such as iTunes.
I often think that people pursuing a valve sound ("tube sound" in US) might do better buying a valve buffer rather than a valve amplifier. The reason I say this is that you can just unplug the valve buffer and return to the non valve sound, which I think will be a bit of a relief when you get fed up with it.
Here is a valve buffer, or tube buffer:
http://www.destiny-audio.com/cms/en/pre-amplifier/tube-buffer.html
It is a "plug-in" but maybe not the kind you were discussing
You mean they couldn't get a real tube in that thing? Wimps. I heard it gets hot, though...My Samsung S8 has a tube sound plugin. So theres that.
Just my newb observation. Linear part of tubes can be replicated by plugin reasonable well. But in saturation where the gold is in music via tubes at least for electric guitar, plugin still has work to do. My marshall modeling amp is good, but it's no mesa rectifier with a half stack. They say tube output stage is visceral.
S8 sells like hotcakes. But Apple always beats them so Apple is hotter.
I disagree. Tube sound is science to a point mixed with a heaping helping of expectation bias.Ok. But I still think tubes are an art vs science. Like saying someone has perfect speech, and you look at the voice spectral response and say
perfect nothing, looks noisy to me. Just having fun.
