Can the sound quality of a headphone worsen due to mistreatment?
Nov 30, 2014 at 8:05 PM Thread Starter Post #1 of 4
Soent
Hello. I've been reading from Head-Fi for more than a year now, but i just recently decided to join the forums because of how informative the community is. I apologize if there's something wrong with this post.
I am using the Shure SE 215 in-ear monitors for quite some time now, having it survived countless drops and cable yanks. Can these type of damages worsen the sound performance of the headphones? Or do headphones take mistreatment until they suddenly stop working?
Nov 30, 2014 at 8:09 PM Post #2 of 4
I cranked one of my headphones to max volume a few times and suspect I damaged the drivers, at least somewhat. A cable can partially short out, but if it starts to do that, it's immediately noticeable. All sorts of other things can go wrong, but it's nothing to worry about until it happens.
Nov 30, 2014 at 10:12 PM Post #4 of 4
Depends how you abuse them!
Usually, a faulty cable would come out as intermittent sound or no sound.
If you mess it up with high volume, then the drivers will be damaged.
Check out the frequency response and see if the base is clear. Usually, the bass becomes muffled if there are issues with the headphones.
http://www.audiocheck.net/soundtests_headphones.php
