Asspirin
Try foam tips
which source are you using?
I’ve been using Comply tips at home listening to Spotify and Tidal through my computer running to a Grace M9XX. At work I have been using spiral dots via a Pixel 2 and a DragonFly 1.5. Foamies definitely sound better, but the ease of use of the spiral dots at work is necessary for me, and I actually feel like there is a bit more bass with the foamies as well.Try foam tips
Quite a bit of burn in, at least 72 hrs. 100+ was where it got best for me.Foam tips are good for boosting bass and calming treble. They don’t cause driver flex either.
@misericorde88 its been noted by many people that the bass will subdue a bit with burn in and tighten up. I noticed this as well.
Ok, I purchased a used Vega last week, and I’m trying to adjust to them. Is there anyone that was initially overwhelmed by the amount of bass, but later adjusted to it? I thought I was a bit of a basshead, but now I’m questioning my life. Previously to buying these I was daily driving the Fostex TH-X00 and thought they had a good low end, but they now sound anemic in comparison. My primary music genre is progressive metal, and I feel like the Vega’s bass makes it hard to discern mids/highs. I also find myself listening at a lower volume than with other headphones because of the bass quantity. I will say that everything about the Fostex sounds a bit muddy in comparison. I plan on snapping up some used Andromeda’s for comparison when I see some available.
Oh, I definitely use it. I just keep it working during the times I'm not able to be listening. Can dial it up louder than normal, too.@HeartOfSky I can definitely try an extended burn in this weekend, but I don't know how you have the patience to buy new gear and not use it for a week.
I agree with everything you said about tips. I played around with all the included ones and several I already had. I messed around with EQ in Spotify, but that EQ is junk. I also have Neutralizer installed, but it doesn't play well with my DragonFly. Paying for an EQ app for $1000 plus iems grates on my sensibilities though.Have you tried using different tips? I found the wide bored spiral dots opened up the mids and highs for me but then on some tracks it was too energetic for me. I personally listen to mines with Comply Smartcore foams. Also try to EQ the sub bass down... It helps if you're willing to do that. But based on you're impressions of the Vega I think Andromeda would much suite your taste.
With everything you've said, it seems that Andromeda would be a much better fit. Vega is so deep and dark in comparison. Andromeda, for me, felt like jumping from cloud to cloud. There was no ground (bass floor) under me to hold me up, but I was still floating nonetheless. The spaciousness of the highs is spectacular. I want to own them as well, even though Vega will definitely be my daily driver.I agree with everything you said about tips. I played around with all the included ones and several I already had. I messed around with EQ in Spotify, but that EQ is junk. I also have Neutralizer installed, but it doesn't play well with my DragonFly. Paying for an EQ app for $1000 plus iems grates on my sensibilities though.
I'll definitely give the Andromeda a shot when the opportunity presents itself.
