Dimension
- Jan 30, 2012
I have been using the k702/k712's for years and absolutely swear by them. My stock cable broke and before I buy another $20 one off of ebay (http://www.ebay.ca/itm/261693766413?var=560560713768&ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649) I thought I would check out better quality (without spending hundreds of dollars) and found this website: http://www.plussoundaudio.com/customcables/headphone.html
I need someone to give me a VISUAL of where these options are for coloring so I know what is being colored, and a recommendation for each other one and why:
Connector
Length (feet)
Wire
Braid Type
Plug
Lower Heatshrink Color
Sleeving
Y-Splitter
Slider
Left Heatshrink Color
Right Heatshrink Color
I thank you in advanced for helping me I know it's a lot to ask Im just more of a visual learner so I appreciate your patience and effort!
Connector
Length (feet)
Wire
Braid Type
Plug
Sleeving
Y-Splitter
Slider
