Tapiozona
- Feb 20, 2008
I'm modding my Denon d2000s, removing the stock cable and adding 3.5mm Jack's on each cup. Problem I'm having is finding the cables I need to work with them after I asd the jacks (not sure what to search).
Here's a picture of what I'm doing and the type of cable I need...
Basically need dual 3.5mm male ends for the left and right channels and a single 1/4 plug on the other side.
Not looking to break the bank on the cable but having an impossible time with what words to search for to find any cables at all.
Basically need the opposite of this (I think)..
Thank you!
Thank you!
