Speederlander
- Jun 21, 2009
$1000 bucks for those things? Holy hell.
Must lol at the review though: Quote:
Is there some kind of audio reviewers phrase generator that lets you spin an arrow to determine the effect(s)? "Big timpani whacks were tauter and went lower"......
Originally Posted by nor_spoon /img/forum/go_quote.gif There's more. These could very well be the final tweak to a system, where all the cables have gone through the burn in phase, and using the NM Sonic Purifiers. You probably need to play a bit with the positioning for the best result... The difference would probably be less dramatically with headphone use though... |
As Paul Candy noted in his review of them, "When the RoomLenses were properly situated, the orchestra became more layered and focused. Brass and percussion shifted further back into the depth of the stage and woodwinds were more defined. Big timpani whacks were tauter and went lower. The soundstage was also slightly wider and airier, with more space around instruments. A slight bit of hash on the upper registry of massed stringed instruments was removed to make them fuller and rounder in tone." |
