NorthernEnd
- Feb 5, 2013
Hey folks,
So I've had a C&C BH portable headphone amp for about two years now, and over the last three months or so I've hardly used it. It's been sitting there waiting for use, so I just picked it up again and I've discovered that the damn thing won't charge!
If I plug the amp in via the mini-USB connector to either my computer or a wall adapter, it will turn on and function as normal (but won't charge), and if I keep it off, it won't show the red light and won't charge at all.
Every so often, when I plug it in again, the red charging light will flash for a split second, then disappear.
The unit is easy to take apart, and I've actually removed the battery to see if there are any issues, but so far I've found none.
Any ideas as to how to fix this?
Alternatively, does anyone know how I could go about obtaining a new battery?
The company that makes the BH is based in China, and I'm wondering if it wouldn't be possible to buy a suitable battery here instead. I just have no idea what to look for.
The battery connects with a 2-pin Molex connector, as seen below.
http://www.shenzhenaudio.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/3/_/3_6_5.jpg
This is the battery I'm looking at as a replacement:
https://www.sparkfun.com/products/339
Thanks!
Thanks!
