The NPO dielectric is so different from the ferroelectric types that it should be in a completely separate category of capacitor, which was my point, really. The NPO types produce little or no piezoelectricity and have zero to miniscule temperature and voltage coefficients of capacitance change whereas the ferroelectric types (barium titanate, etc.) sacrifice everything to achieve a high capacitance per unit volume.
Attempting to use a capacitor's series resonant frequency to precisely null out ringing/oscillation is, admittedly, a tad beyond the scope of this forum's pursuit
. However, the document you referenced, ppl, seems to be a bit Spartan in the details about just what ceramic capacitors were tested - not to mention that the part numbers of the other capacitors tested indicate that the data are a little outdated (polycarbonate, for example, is no longer being produced as a film for capacitor dielectrics - what is available today is what is left of a very finite supply). So, perhaps they tested Z5U ceramics, in which case, yes - they suck for pretty much any use, even bypassing, in audio. But X7R's are a bit better, and NPO's aren't even in the same league. Of course, the low
k of NPO dielectric means you won't often find capacitance values of more than 1000pF, but part of the point of the TI document was that more capacitance does not necessarily improve the decoupling of an op-amp's power supply.
Furthermore, while it is important to know how much distortion a capacitor introduces to a signal
if it is used for coupling, it is not at all relevant when used for
decoupling. The ESR and ESL of a capacitor are pretty much the only relevant parameters w/r/t decoupling. In this respect, then, NPO ceramic reigns supreme. PolyPhenylene Sulfide capacitors look pretty good, too, but I don't know enough about this dielectric yet (aos - isn't this dielectric one that you favor for bypass applications?)
If you're using a ceramic as a noise reduction capacitor for an ultralow noise voltage regulator, then microphony will bite you. |
aos - what kind of ceramic? I would think that the amount of capacitance required in this application would preclude the use of NPO... Correct?
