TwinQY
Something about the rear end of a cat
Bassy but crisp, under $50? Sounds like the CKS55 or the E10 to me.
Neutrality and a durable cable, $75-150? Might want to look at the RE-400 or the BA200 if you mind a little warmth added to the mix (otherwise quite linear). Cable on the RE-400s are decently thick, only qualm IMO is the rather large and angled jack. The TDKs have a flat cable so take from that what you will. The BA200s insert fairly deep with the right tips, the form factor helps a lot as well. If the RE-400 nozzles work well for your canals they can also go in pretty deep.
I actually did ask about his preferences and other criteria, but he never replied so...
That list is so disparate I'm not sure where to begin - seems all over the place really.
The EX600 deals out pretty much the same signature as with the EX1000s - but since you are against sibliance neither would really be ideal unless EQ is in the cards.
Haven't heard the Tai Chi, Taurus or the T-Peos but the MG7s might be a bit uneven around the upper mids, though pretty smooth and laid-back as a whole. The FADs are really not for someone who's against an uneven treble.
I am looking for something that is a good all-rounder. I like to hear the bass as well as crisp sounding vocals. I am not an audiophile so I am not to familiar with the terms.
Basically looking for something with the best value-for-money at $50.
Thanks
I need some help in buying new in-ear headphones as my current set is dying. What would you guys recommend?
Budget: £100($150) maximum, but I would prefer something in the £50-80 ($75-120) range
Music taste: These will be used for rap 90% of the time
Using with: Usually I will be using these with my mobile phone (Sony Experia S).
Other Requirements: Good noise cancellation and neutral sound as I might use these as monitors while recording. I also would want something that has fairly durable cable or a replaceable cable like the Shure Se215.
Other Info: I have Denon AH-C710 and really liked the sound these produced so I wouldn't mind something that sounds similar but they died![]()
Quote:Hey..... yeah... its me... again..... I tried the Westone um1.... and all thanks to that i cant decide between the hf5 and the um1.... HELP PLZ WHICH 1 IS BETTER
Not that I've heard either of them, but I imagine that the question will come up sooner or later, so... exactly what do you mean by better?![]()
And OMG, its too expensive for my budget now. What are the cheaper iem's ($200) with similar signature with those sub bass rumbles, and heard the treble is too bright in some tracks is that true ? I would want it to be lil smooth,I dont mind sacrificing minute details. Just want to hear good and fun sound, with mids coming forward and live, I hate laid back vocals.
I hate when the high's screech or produce (ssss sound) . Sorry I am asking too much, but just wish there is a good iem out there, which could satisfy my taste.
I guess atrio mg7,accutone taurus,T- peos h-100,final design adagio III,radius ddm2,dunu dn-19 tai chi and hippo vb fits my criteria ?
Or any other iem which has similar bass as these ?
