ericx85
- Dec 3, 2014
Supercharger is probably as good as a switch mode can get for now
Yes, I like how it works for the GT.Supercharger is probably as good as a switch mode can get for now
Adding a linear power supply won't be that much of an improvement over the super charger. Having the super charger along with the op-amp upgrades transforms the GT into one of the best solid state amps out today.Thank you. I use the GT with the super charger from the beginning. Just wonder if I need to upgrade it with a very good LPSU..
Well, there is a room for more experiments with the sound along with the streamer/ DAC / power supply upgrades...upgraded op-amps over those
Yes, every piece in your chain matters when it comes to maximizing performance. Eventually I want to add a streamer to go in front on my M-Scaler. I'm also thinking about swapping out the power supply in my DAVE with an LPS.Well, there is a room for more experiments with the sound along with the streamer/ DAC / power supply upgrades...
Interesting, I was using config #2 for the longest time. Very recently, I went to config #1. It's strange that the sound just dropped off like that.I was having issues with low bass/separation in my system. I opened up the GT, blew out the dust and went back to stock config and that solved all my issues. (Previously config 2)
Can't tell if it was the config change or the dust buildup causing these problems because I remember config 2 having tons of bass but it just stopped after awhile.
Yeah. I always thought the problem was the TC but as I've come to learn after about a year in this game: the headphones simply just do what the electronics tell them to. If you aren't hearing what you want to, mostly all of the time it will be the electronics.Interesting, I was using config #2 for the longest time. Very recently, I went to config #1. It's strange that the sound just dropped off like that.
Having a good source chain is very important in our hobby. Maybe more important than the headphones themselves. I tried building a system around the Susvara's and it didn't workout that great. It optimized the Susvara's sound, but my other headphones not so much.Yeah. I always thought the problem was the TC but as I've come to learn after about a year in this game: the headphones simply just do what the electronics tell them to. If you aren't hearing what you want to, mostly all of the time it will be the electronics.
That said I'll go back to trying other configs as running all Vivids is in no way optimal lol.
It’s really comes down to what’s sounds good to you and what works well with your headphones. I really liked configuration #2, which sounds a little bit more resolute and spacious, but gives up a little impact and dynamics. I like configuration #1 because my headphones are high resolution already. This configuration works better with my headphones as it gives them more bass presence, a midrange boost because forward presentation, and improves their dynamics.Thanks...and it definitely was the dust.
What is the best config? I moved the Sonics up to the volt gain as I feel that is the stage most sensitive to the characteristic of the op amp. Feels like you have even more detail and bass than having the Vivid there blurring it all up.
I don’t think so, I have a friend who daisy chains his amps. You are technically double amping, so be careful with the volume levels you are feeding the GT. It does have max input voltage rating that you don’t want to exceed.I am feeding the soloist 3x gt to susvara. To make the story short, I found that if I use my singxer sa-1 as a pre-amp and feed that into the 3xgt, I am getting slightly better bass, while also getting very slightly less clean treble, but that's ok. The sa-1 is set to high gain, and pretty much has the knob turned to the max. Xlr balanced throughout. With the sa-1, I set the amp to mid gain and volume normally stays around 25. Without the sa-1, I need high gain with nominal volume at about 40. My question is: will using the sa-1 with this kind of setting cause any potential damage the amp?
