Mad Myall
Got some TH900mk2s, what do people recommend I swap the Op amps out with, and what effects would they have? I love me some juicy base, Is there a guide on a lot of these op amps somewhere maybe?
@lightoflight created a great comparison/op-amp configuration chart here. Check it out to get started. It’s very detailed.Got some TH900mk2s, what do people recommend I swap the Op amps out with, and what effects would they have? I love me some juicy base, Is there a guide on a lot of these op amps somewhere maybe?
Superb! I'll need to start grabbing some of those extensions it looks like so I can fit the op-amps, they be pretty fat@lightoflight created a great comparison/op-amp configuration chart here. Check it out to get started. It’s very detailed.
Yep, depending on which configuration you settle on you’ll need them.Superb! I'll need to start grabbing some of those extensions it looks like so I can fit the op-amps, they be pretty fat
You don’t think that there’s too much power? On medium gain with my HEKse I can barely get to 30 on the volume dial without GT blasting my ears.While listening to the GT with my HE1000se, I find myself enjoying the distortion of the high gain mode with op-amps configuration A. The bass thump in high gain is outstanding too. Moreover, I definitely got my EQ settings right on the spot after countless days of adjusting.Now, if this summer heat would go away, I can do more listening with the GT.
My SIL 994’s are in route, but I like configuration A myself. Most of my headphones have great soundstage already. So I’m looking for more bass and dynamics. Having the SS2590’s in the Volume Control Buffer gives me that.
I have dedicated power line for my audio gears, and still I use Isotek Evo3 Aquarius for digital source. It gives you blacker background, better separation, cleaner treble, deeper and bigger staging image. Yes, for power amp or pre amp, I use Furutech power strip plugged to its non filtered outlets.Hello!
About to become a BAS 3X GT + SC 5A PS owner. Trading in my a90/d90mqa stack + focal clears towards getting them. Also, trading in my sundaras to Hifiman for credit towards HE1kSE. My setup for the past year has been the stack listed above with the Focal Clears + Senny HD800S. I debated just saving for the susvaras and being at or certainly close as hell to endgame (I hope!), but hifiman customer service offered me a solid value for the trade in towards the HE1kSE. I figure I'll enjoy them and my HD800S while upgrading my setup to higher end amp/dac/ddc stack + the HE1KSE. Perhaps in the future I'll request to trade up for the Susvara.
I'm still going through this thread, so I apologize if someone has answered this particular dilemma. I'm currently at the "clean" power aspect of the amp/setup. Prior to this, I was just going to connect the setup to a surge protector I have that also has my PC + myriad of other components attached to it. Alas, I arrived at power conditioners. My question is if having an electrician come to my house to add an outlet that would solely power my audio gear would be better than investing into a power conditioner. Would I still need the power conditioner or be better off doing both? The more I read into this thread the more I feel my end game setup requires an additional component to ensure the optimal conditions for it to thrive.
I need to contact local electricians and see how much they'd charge me to run a new line specifically to be used by my audio gear. I figure if it's too pricey I may just put that $ towards a decent power conditioner. But as stated above, I should definitely focus on solidifying my audio chain first and then focus on other things to clean up the signal. I'm sure the audio chain upgrade will be a far greater SQ improvement than interconnect cable upgrades + clean power improvements. 1 step at a timeI have dedicated power line for my audio gears, and still I use Isotek Evo3 Aquarius for digital source. It gives you blacker background, better separation, cleaner treble, deeper and bigger staging image. Yes, for power amp or pre amp, I use Furutech power strip plugged to its non filtered outlets.
I don't see any source components in your signature, I assume you're using your "normal" PC as player/streamer, right?I need to contact local electricians and see how much they'd charge me to run a new line specifically to be used by my audio gear. I figure if it's too pricey I may just put that $ towards a decent power conditioner. But as stated above, I should definitely focus on solidifying my audio chain first and then focus on other things to clean up the signal. I'm sure the audio chain upgrade will be a far greater SQ improvement than interconnect cable upgrades + clean power improvements. 1 step at a time![]()
