As planned I have went to try the virtuoso demo unit and just focused on the background. Unfortunately at one shop which the environment is quiet enough they don't have lcd3, while for another shop which can provide lcd3 don't have a quiet enough environment due to the sound of an air circulation fan.
I have tried audeze lcd-x, lcd-xc, lcd3, and fostex th500rp. For the lcd-x, lcd-xc, th500rp, there was a very faint hiss sound noticed when the power is on, the level are similar to my k812 (way lower than in case of th900). I consulted the shop manager and he thinks that the level of the hiss is very very low (which he considered almost none) and is acceptable as audiophile. I would comment that such very low level of hiss is still noticeable when you focus on it, but when music is on you will not be affected at all, but for some classical music as PeterCV mentioned, it is arguable.
For lcd3, honestly I am not very sure if there is any hiss due to the environment. I try to focus on it and I feel there is some difference when compared with power off. But even IF there is, it is likely way lower than in case of lcd-x and lcd-xc and can be regarded as nil.
I would like to hear further comments from other head-fiders, including that of Dark Ayla after he has received his virtuoso.
P.S.
lcd3 with open back sounds better than lcd-x and lcd-xc, if I have to swap into audeze I'll certainly choose lcd3
