Built my PC! But I have some Qs regarding stuff . . .
Jul 16, 2005 at 3:19 PM Post #31 of 33
Yep, using onboard sound from the motherboard. Not too bad for stock quality, but the volume is just way too low. There is also a jack on the case itself, but I didn't hook it up. Gonna try that. Oh, I use both the system device and utility to change sound, both maxxed.
Seems like a great drive!
You mean the nec?
I chose the benq due to reviews, doesn't really matter, I don't think I'd notice the difference. Anything's better than my old stock burner. (on my p3, took 20-30min to burn a cd-r, on the same system the benq does it in 7 minutes!)
Jul 17, 2005 at 3:37 AM Post #32 of 33
Okay i'm pissed. You guys know that drive I mentioned before that wasn't working with the pc, the benq? Yeah . . . I put it back into the old system, and it worked fine. Ejected and closed normally, and burned a disc too. Returned it to the new system, and it f**ks up again like before. Won't auto eject/close. Just a popping noise, like the tray is trying to come out, but not. Even upgraded the firmware. I don't get this . . .
Jul 17, 2005 at 3:54 AM Post #33 of 33
Originally Posted by akwok
Sorry ATOL.. there are no CPU drivers :-(.
And CPUs don't really burn-in.. you might have been lucky
. Or something else offsetted the locks.
The Athlon 64 Drivers here
http://www.amd.com/gb-uk/Processors/...1_9706,00.html
