In my honest, hearfelt opinion, the entertainment of possibilities has begun to spin a tad out of control, and I do believe it's time for a little grounding. As a college student, I understand how hard it is to earn an income. As a fellow Head-Fi'er, it would pain me to see you spend more than you need to.
SO... understand that the purpose of this post is to aggressively talk you into a more reasonable setup. Seeing that the one suggestion you made for yourself in your post was the best I've read so far, it's also to persuade you to stop taking suggestions from sub-standard magazines like Computer Shopper and do more thinking of your own.
I'm going to first jump straight to the most important question in your post because I feel it's at the heart of the issue:
For my stated goals and needs, what do you think: is it worth spending a bit more for these core items (sub-total: $895.48 USD)?
No, it is not. You do not fold, compile, render, or game. Instead, you are going to use this computer for word processing, web browsing and tinkering. Let's be realistic here -- the extra cash you shell out is simply going to go to waste because you will not utilize the extra potential your hardware offers.
Now let's go through this one by and one and see why.
First, they recommended an middle tower size aluminum chassis with a removable motherboard tray. They liked the Cooler Master ATC-110 case but pointed out that the Lian-Li 6070 case ($159.99 USD @ NewEgg.Com) is also a contender because of its similiar feature set and the kicker is that the latter case is noise-dampened too.
The main purpose of choosing a proper case is to ensure that it will not restrict your upgrade options. The cases listed are filled with open bays. You mention that you only want one HDD. There is no reason to pay for extra bays which will for certain lie around empty.
As for the aluminum chassis, it is entirely unnecessary. Aluminum chassis are supposed to have the upper hand by a thin margin when it comes to thermal dissipation, but you stated that stability is your first and foremost concern so I assume you will not OC, which means you will not notice the difference. In fact, aluminum chassis are a poor choice if noise is an issue -- steel cases provide the best isolation because of their density. The only reason I can think of where you would need an aluminum case is if you move around frequently, as steel cases can be rather heavy.
Second, the Antec 550-watt Modular True-Control power supply ($103.50 USD @ NewEgg.Com) was their choice. They chose this particular model because more powerful CPUs, GPUs, and peripherals will absolutely demand more electrical power.
I personally wonder why they chose the Antec for their "Dream PC" when PSUs from PC Power & Cooling are known to be top dog, but each to his own.
Applied to you, this means absolutely nothing. The system you will build will not consume anywhere near 550 watts, nor will it come anywhere close to the 80% headroom. Again, you will end up with loads of wasted potential, which directly translates to a waste of your hard-earned dollars.
Third, they recommended the Asus A8V Deluxe motherboard ($129 USD @ NewEgg.Com). It is one of the first to support AMD's Socket 939 platform and it is a standard ATX-form-factor board that uses Via's K8T800 PRO chipset. The feature laden motherboard supports dual-channel memory support, AMD's HyperTransport bus technology, four Serial ATA (SATA) channels, two RAID configurations due to the two onboard RAID controllers, Gigabit Ethernet, eight-channel audio (not that I need or want that
), and built in 802.11G card and antenna.
There is a lot of hype packed in there. Current HDDs barely push ATA100 limits, much less SATA. The only pro-SATA reason I can think of when addressing your set of circumstances is that the wires are thinner and will result in a slightly cleaner interior.
Two onboard RAID controllers? You are planning to use one HDD so the RAID controllers be touched -- two onboard RAID controllers just means you're going to waste twice the amount of dollars.
Gigabit Ethernet is hype as well. I highly doubt that at this point, you will need anything above 100Mbit Ethernet.
As for the built-in 802.11G, I only shudder at the thought of what sort of chipset that's using. Do yourself a favor -- buy a simpler motherboard with features you will use and pick up a WLAN card with an approved chipset later on if you feel the need to setup a wireless network in your house.
Fourth, it looks like the Corsair TwinX XMS PC3200 DDR RAM got their nod. I am curious about TWO Corsair 184 pin 512MB DDR PC-3200 OEM RAM sticks ($156 USD @ NewEgg.Com). Is my choice even compatible with this motherboard and my CPU choice?
Why do you need Corsair RAM? The whole purpose of picking up Corsair is to be able to tighten memory timings and squeeze the last drop of performance from your hardware. But you aren't going to OC. Again, this is a big waste of money. Corsair dropped the ball a few months back and was turning out under-performing XMS packages anyway. Try 1GB of Crucial RAM, it's a much better fit for your situation (you don't need tight timings, but may heavily multi-task, so 1GB will most likely be appreciated).
Fifth, the all critical selection of Intel or AMD CPUs came down to the AMD Athlon 64 FX-53 for their nod. It is much too expensive for me. I am curious about the AMD Athlon 64 3200+, 512KB L2 cache OEM 64bit CPU ($190 USD @ NewEgg.Com) or the less expensive AMD Athlon 64 3000+, 512KB L2 cache 64bit CPU. Will either one work with the aforementioned motherboard?
Again, the question comes: You do not fold, compile, render, or game. Instead, you are going to use this computer for word processing, web browsing and tinkering. What need do you have for an A64 3000+? Future proofing? Read on and I'll tell you why you don't need to worry about that right now.
Sixth, Computer Shopper chose to go with two Western Digital 74GB Raptor Enterprise SATA WD740GD HDDs ($178 USD each @ NewEgg.Com) spinning at 10,000 RPMs and they setup a RAID Level 0 configuration thanks to such capability afforded by their choice of a motherboard. They also chose the Western Digital Caviar SE SATA WD2500JD 250GB 7,200 RPM HDDs ($156.99 USD each @ NewEgg.Com) in the same RAID Level 0 configuration. I don't need that much storage space. What about ONE WD Caviar SE SATA WD2500JD 250GB 7,200 RPM HDD with no RAID configuration? Will that work?
It would work, but it wouldn't be practical. There is no doubt those HDDs pump out massive amounts of noise and heat. Are you running a database server? Do you do video editing that requires constant HDD access? 3 milliseconds, if that, of longer wait time to save a Word document isn't that bad, trust me. Do yourself a favor and buy a Samsung Spinpoint -- I promise that you will not notice any different in real-world performance. Your air conditioning bills and ears will thank you.
Let's talk sound and vision. I am curious about this video card: ATI AIW RADEON 9600XT Video Card, 128MB DDR, 128-bit, FM/TV/AV In/AV Out, 8X AGP, Model "ALL-IN-WONDER 9600XT" w/ REMOTE -RETAIL ($189 USD @ NewEgg.Com). The reason why I am interested in it is due to the fact that it will give me AM/FM radio, coaxial cable TV, MPEG-1&2 video capture, TV ON DEMAND (i.e., TIVO capabilities). However, I am concerned about the Linux driver compatibility. I am thinking about the Chaintech AV-710 7.1 channel ($25 USD @ NewEgg.Com). There has been a lot of talk about how it represents a stone cold bargain. Sub-total: $214 USD.
Let's talk common sense! This is an EXCELLENT decision -- and the best part is this is only decision in your post you made yourself. See how this is turning out? You're doing a much better job than Computer Shopper is doing. They don't know what they're talking about -- you do.
I am keeping an eye toward future proofing. The reason why I am choosing a motherboard capable of supporting a 64bit CPU is because I think it is the future of computing...someday. There are 64bit Linux distributions available for free. There are a few 64bit open source programs available on such 64bit Linux distributions. I expect that more applications will be made available as the enticement of 64bit computing whets more of an appetite by hardcore computer geeks (like myself) and later the masses.
There is nothing extra for you to tinker around with on a 64-bit system if you aren't using 64-bit applications. Since you don't fold, compile, render, or game, there really is no purpose is wasting the extra money now.
As I had suggested to you in PM, I suggest you do the following:
- Build a budget desktop for yourself. Impose a sub-1000USD limit for the tower, and be a little more liberal for the monitor. If you feel like you need a new desktop now, build it now -- you have nothing to lose. What is available currently will last you until the next big wave.
- Toward the end of next year, we should start seeing dual-core offerings for the average desktop appearing from both AMD and Intel. DDR2 should be faring much better as well (the latencies are a little high at the moment, but as things begin to scale, the advantages should become more and more apparent)
- Come 2006, Longhorn will be released... but probably with two major features, WinFS and Avalon left out. You should probably avoid becoming an early adopter and let things work themselves out for a little bit before jumping in.
- Sometime 2007/2008, when WinFS has been released, the slew of expected bugs have been fixed, and driver support has become more and more mainstream, you will be in the optimal position to upgrade, either to a desktop or a laptop, either of which should be more than you will need for years to come.
It's the plan I'm probably going to stick to, the only difference being that I'm running on a laptop since I have to fly overseas every winter/summer.
Hope my response makes sense, let me know if you have any questions.
Good luck!
