shake
- Dec 13, 2009
The inputs are going to be RCA jacks. What do you mean by ground at the amplifier? Ground to case at the input jacks or somewhere in the amplifier circuit? The case is going to be grounded by the output/input jacks and I don't know if Alps pots ground the case as well.
So the transformer/rectifier/regulators/caps are their own ground, and I have a wire from there going to the TRS ground of the output jack where all other grounds go?
Yes, that is the right idea. As wakibaki also suggested, if you are using a shielded cable for your input,
it can ground at the amplifier instead of at the power supply.
a single "star gnd" is usually "too simple" to be "the best" - I use a hierarchy - gnds may be dirty/noisy or clean - to varying degrees
the power supply xfmr CT/rectifier/reservoir caps have the largest current spikes, they should be a separate "star", then a branch from there goes to the "clean gnd" "star" point, the Vreg reference terminals can be "between" the two, "Kelvin Sensing" actually runs these to the clean gnd
my output connector star drawing, shown in the 1st post can be about as good as it gets if you only have one channel - or go "dual mono" = two completely separate amps, power supplies, separate R,L connector headphone gnd pins, "balanced" headphone connector
if you have only a single dual polarity supply, and/or use the shared common R,L gnd TRS connector you have to compromise from that ideal
I think a good compromise is to use the TRS common gnd as the "clean gnd star point"
when everything can't be at the same point you can sometimes get near the same effect by making the resistance between them low with gnd planes on a PCB or heavy Cu buss - Cu Roof Flashing is the most easily available Cu sheet stock
